-   -   Fuse panel upgrade to ATO type (http://forums.pelicanparts.com/porsche-911-technical-forum/194614-fuse-panel-upgrade-ato-type.html)
targa80 11-30-2004 01:13 PM
There have been several other threads on upgrading the fuse panel to the ATO type fuse. I have been wanting to do this and have been searching the web for suitable parts to do the job. I have found a fuse holder made by littlefuse that can be ordered at mouser.com.
The fuse holder is capable of being snap-mounted from the rear to a panel with the corrct hole size also the fuseholders interlock for multiple mounting. They have two types one is rated up to 20 amps and the second is rated for 25/30 amps. The wires are connected to spade terminals from the back. The width of each fuse holder is just under 1/2 inch. The old fuse block is 12 and 3/8 of an inch long. I believe that at least 24 fuse holders can fit in the same space as the old type.
I just ordered sixteen of the 20 amp and ten of the 30 amp holders along with fuses and an assortment of male female spade terminals. The total cost is $62.50 without the shipping. The dimensions of the fuse holder are 1.2" L X .4" W X 1.46" D If anyone is interested the mouser part numbers are 5768-55300 for the 20amp and 5768-55400 for the 30 amp. They have a data sheet and picture in a PDF file.
mtelliott 11-30-2004 01:55 PM
Are you planning on replacing the entire fuse block? I've been sent dimmensions for replacing the entire panel with a new that holds ATO fuses but haven't attempted to replicate yet. What always gets me is which one's to splice together.
What's your plan? Are you going to replace the fuse blocks with your own creation or what?
RallyJon 11-30-2004 02:15 PM
Isn't that a big problem? You have to mount the whole thing set off from the body by an inch or so for clearance, plus maintain some way of disconnecting everything to get around back to the spade lugs if needed.
randywebb 11-30-2004 03:20 PM
What we need is a modern fuse holder that has the same size and screw terminal layout as the ones already in there - that would give us an easy install.
I'm sure you could sell 1,000 of these -- and surely somebody would do up a production run for that number.
toolman 11-30-2004 05:05 PM
I'd buy one right now if I could.
fred cook 11-30-2004 07:36 PM
ATO Fuse Holders......
Here are a couple of pictures of the fuse conversion that I did on my 1980 SC. The first picture is of the mounting plate (made from aluminum sheet) with the holders installed. Note that the terminals are on the side, thus easy to access once installed in the car.
http://forums.pelicanparts.com/uploa...1101871555.jpg
The next picture is the completed fuse panel as installed mounted in place of the original fuse holders.
http://forums.pelicanparts.com/uploa...1101871742.jpg
The hardest part of doing this conversion is identifying all the jumpers that are hardwired to the back of the original fuse holders and in some cases done with a piece of wire from terminal to terminal. Also, be sure to strip the wire ends back about 1/4 of an inch to eliminate any corrosion that may have grown on the wire ends. Most important of all, tag the wires as your remove them from the original fuse holders. Once all the wires are removed, it would be a nightmare to try to get everything in the right place without the tags. If anyone would like to build an installation like the one I did, send me a pm with your email address and I will send back some drawings and wiring info that I put together.
Fred Cook
'80 911SC coupe
RallyJon 11-30-2004 07:43 PM
Fred: this one, right? Did you get them from www.vehicle-wiring-products.co.uk or is there a U.S. vendor?
http://www.vehicle-wiring-products.c...hoto/fha16.jpg
Brother 11-30-2004 08:10 PM
Pat,
Why not go with the mini fuses? I think I might try the same thing. I think I'll start with the ones in the engine bay first.
Glasgow 911SC 12-01-2004 02:20 PM
Just a word of warning about these holders. I ordered a few of them to update my rear fuse panel. The heated rear screen melted them without blowing the fuse. They must only be 20amp holders.
fred cook 12-01-2004 06:53 PM
Fuse Holders.....
Nope, that's not the same as the ones I used. Mine came from Norway via Ove (a PP board member). They cost about $1 each plus shipping. They are rated at 20 amps but I haven't had one melt or cause any trouble thus far.
Fred Cook
'80 911SC coupe
CBRacerX 12-01-2004 07:55 PM
Fred - Nice job!!!
I'm not ready to tackle that yet, but I can see it coming!
Chris
Brother 04-06-2005 06:25 AM
nice
Wil Ferch 04-06-2005 07:22 AM
Fred has the text book example of how this should be done...
When ordering holders, two points:
- amp rating....20A is typical but some of our circuits require 30A...either upgrade or separate the load.
- each fuse holder should allow individual input /output....some "boards" use a ganged input which isn't correct for our application....
Wil
vizail 04-07-2005 07:47 AM
Fred
Very nice update/modification. But how come the fuse holders only rate 20amp?. Is there an Alternative fuse holder that can be rated more that 40 amps?
Cordially
VicSmileWavy
}{arlequin 04-07-2005 12:49 PM
great job Fred. That's something I should get started on as well.
vizail 04-07-2005 02:36 PM
Just send you a PM
VicSmileWavy
fred cook 04-09-2005 10:30 AM
Fuse Holder Project......
Sorry guys, not trying to ignore your requests, but I've been off camping for a few days. When I get back to the house I will send the fuse / wiring info out to all the new requests.
fred cook 04-09-2005 08:01 PM
Flat Fuse Conversion.....
The company that makes the 20 amp fuse holders that I used (Zirman) also has a 35 amp bakelite version but I have not been able to find a vendor that carries them. They are available from the factory but that would take a $5,000 minimum order!
The only fuse position that I found that pulled over 15 amps is the one for the evaporator and front condensor fans. I just separated them to work off two fuses. If you have high wattage headlight bulbs, best to add the headlight relay conversion. The conversion that I did allows room for 24 fuses, 3 more than stock and the stock cover will still fit over the holders. I have had this conversion in the car for a little over a year and have had to replace one fuse holder. It was the one for the fuel pump relay fuse. It got overheated because of a poorly done connection (my fault) on a short wire that was difficult to work with. Once I replaced the end connector properly there have been no further problems.
RoninLB 04-10-2005 01:01 AM
Fred did a great job with big dedication imo.
I've been interested in up-grading the stock crap myself. I kinda lean towards Cole Hersee and Blue Sea Systems. The highest amp on the CH is 25amp and routine on the BSS is 30amp. The best contacts I've been able to find are tin plated copper. I'd be interested if anyone has found silver plated copper.
thx
911SCfanatic 04-10-2005 06:58 AM
The fuse upgrade is going into my '72 project along with relocating the blocks and battery to the smuggler's box. Thanks for the info and be sure to post more details as you get them.
}{arlequin 03-07-2006 09:06 AM
Re: ATO Fuse Holders......
Fred Cook
'80 911SC coupe
ok guys. i'm getting ready to start firing up this project, and want to find out what gauge of wire is used that's running into the fuse box. does anyone know? 14? 16?
i'm planning on having lots of 10 and 12 gauge on hand for lights and various other functions, but the ones that go to the fuses seem thin...
thanks.
RallyJon 03-07-2006 09:50 AM
Metric sizes. They're listed on the wiring diagram. Eagle Day sells it:
http://www.eagleday.com/neauwi.html
Mysterytrain 03-07-2006 12:32 PM
The key thing with rewiring the car is to try to maintain the same color codes on the wires and the same positions for the fuses. I would also document everything and draw it out like the factory wiring charts..not only for the next owner but for yourself 6 months from now.
}{arlequin 03-07-2006 12:44 PM
i have no problem keeping track of the colors etc... i am ready to order wires and i just don't know which gauge is the one that closest resembles the factory wiring into the fuse box
fred cook 03-07-2006 01:09 PM
ATO Fuse conversion.......
You should find that most of the wires will be long enough without having to splice on an extension. The only exception that I ran into was a white wire that was a small gauge and plugged into the holder on the top side. Of course, that might change on your car if a PO has shortened any of the wires (to eliminate corrosion, etc.). Also, I used connectors that were uninsulated and added heat shrink after crimping/soldering the terms.
}{arlequin 03-07-2006 01:28 PM
thanks fred.
my plan was to "replace" as much of the wiring as i could get my hands on, hence the gauge query. i figure by now it's old and brittle enough to warrant some refreshing. while i cannot replace all of it, i would like to at least do it with what has been, in my opinion, exposed to the harshest conditions, mainly, everything i can locate in the trunk area.
it also just doesn't make sense to me to use some quality sealed connectors that would be crimped onto ancient wiring.
fred cook 03-07-2006 07:49 PM
ATO Fuse Panel.....
I found that on my car (1980SC) that by cutting the wires back about 10 mm's that I would be back into clean, flexible wire and insulation. By adding another splice point, you might be adding more resistance to the circuit than by just cutting back to clean copper. Just a thought. If the wiring is really cooked, you might be better off buying a new front wiring harness and really do the job right.
}{arlequin 03-07-2006 10:23 PM
acknowledged. it's all up in the air, but i just cannot afford to disconnect everything to find out that a lot of it is bad and that i have no wires to replace it with.... fyi: i do not have a garage... all my projects must start and end within 2 days (sat + sun)
