-   -   911 block heater (http://forums.pelicanparts.com/porsche-911-technical-forum/194647-911-block-heater.html)
tkrefeld 11-30-2004 03:23 PM
911 block heater
I just bought a magnetic 180W block oil heater for my diesel tractor and thought I would put it on the 911 before I head out for my winter drives..where would I put this thing?? Under the engine drain screen or on the oil tank??
Grady Clay 11-30-2004 04:27 PM
I have about the same wattage on my sump plate. It has worked well since ’68. Today, I would add a flexible 40-60 W heating element on the sump tank. There is no substitute for a hot-air 1500 W heater under the engine & transmission for an hour or so before start-up.
Best,
Grady
Oracle 11-30-2004 10:54 PM
Re: 911 block heater
Hi,
Where did you buy that??
That's exactly what I've been looking for!
-J
tkrefeld 12-01-2004 04:35 AM
Tractor and heavy equipment store...Farm and tractor supply may have it as well..You can also get them online with a web search for KATS heaters..The guy told me the dipstick heaters don't work well at all...
