-   -   Project ITBs: mock-up (http://forums.pelicanparts.com/porsche-911-technical-forum/194689-project-itbs-mock-up.html)
jpnovak 11-30-2004 07:14 PM
I was lucky enough to have some parts cut this weekend. A good friend hooked me up with some CNC mill time and cut these great plates for the base of my throttle body project.
The plates are a press fit to the tubing I will use as my runner. It has a 41mm ID and closely matches the GSXR throttle bodies. Here are a few shots of the mock up. Next step, get out the welder.
http://forums.pelicanparts.com/uploa...1101870813.jpg
http://forums.pelicanparts.com/uploa...1101870833.jpg
jpnovak 11-30-2004 07:15 PM
Oops! forgot one.
http://forums.pelicanparts.com/uploa...1101870919.jpg
MotoSook 11-30-2004 07:16 PM
Nice work Jamie! NICE!
smestas 11-30-2004 08:51 PM
Jamie,
Will those mount directly to the heads or will you have some sort of manifold between the ITB and heads?
widebody911 11-30-2004 09:01 PM
So you're putting motorcycle carbs on your 911?
sammygon1 11-30-2004 09:03 PM
Looks good, any luck on the linkage yet? Sam
jpnovak 12-01-2004 06:49 AM
Thom, Here are the two links previous. Souk is putting MC carbs on the 911. These are fuel injection throttle bodies. Yes, they are from a motorcycle. Cheap, easy to find and allow individual throttle bodies for my EFI conversion.
http://forums.pelicanparts.com/porsche-911-technical-forum/180639-project-itbs-part-1-parts-arrive.html?highlight=itb%2A
The current design has them bolting directly to the heads. I may modify this to mount on weber manifolds.
Sam, I have a design in mind for linkage. Once I get a set of 3 mocked up I can see if it will work out.
Mike Bonkalski 12-01-2004 07:01 AM
Very cool Jamie. I am very interested in how you linkage turns out.
ValveFloat 12-01-2004 07:59 AM
Very cool. I've been following your project. How will the TB attach to the tube?
jpnovak 12-01-2004 08:27 AM
the TBs will eventually be welded to the tube. I will likely clamp a rubber sleave to do some testing with intake length.
jmshepard 12-01-2004 04:12 PM
Jamie,
This is great work. I have started winter project along the same lines. Just so I don't reinvent the wheel (incorrectly), would it be possible to post the dimensions of the plates that the CNC machine used for the milling? A CAD file in a .dxf or .dwg format would be even better.
Thanks in advance,
Jim S.
