I have an 87 coupe with over 100,000 miles on it. I plan on replacing the shocks with Bilstein HD and going to turbo tie rods. I also want to do the suspension bushings. From what I can find for the rear I can choose from poly-graphite, poly-bronze or neatrix. I'm going to go with the neatrix.
It's the front I'm not sure about. My choices seem to be poly-graphite (noisey and squeaky plus a hard fit) not willing to except. Or poly-bronze which are expensive. Are there any other choices out there for the front? If not I guess it will be poly-bronze. thanks
Jerry Baer 87 Carrera Coupe |
Smart Racing Products can replace the rubber bushings in the front a-arms for about $ 400.00. If it were me, I would replace all my bushings with poly-bronze. Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Don't be cheap buy nice parts (poly-bronze) once and be done. Also save yourself the headache of having to do the project over again when the rubber bushings start to bind and squeak.
72T RS look 96 993 |
My stuff is just arriving from different places for my winter project. I tended to also look at the ease of installation as a factor. 'turning' the bushings for fit and the potential for squeak was a big turnoff.
I put bilstien sports on last year. My recently ordered parts include... turbo tie rods, elephant front poly, rennline control arm rears, neatrix spring plate bushings, 22/29 torsions. when its apart, i'll also look at the ball joints (118k miles). I havent decided on doing the sway bar bushings yet... not a big deal, but new sways (and thus new bushings ) might be a phase 2.
Database and Website Consulting Services in Chicago |
