LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
another round please
strupgolf's Avatar
jack stand locations
Where are the correct places to place some jack stands, front and rear, to get the 86 911 up for some look-ats and some work. Its a widebody so not much room. Thanks for your reply
Getting old is not for wimps.
Old 11-25-2004, 05:29 PM
Semper drive!
rcecale's Avatar
I can't answer for the front, but for the rear, place the stands here...
NOTE You may want to place some cardboard or something between the stand and the car to prevent removing the protective coating.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 11-25-2004, 05:37 PM
rhk109's Avatar
The front most torsion bar mount is perfect for jack stands. Be careful when jacking up the car high enough to get stands on the front and rear. It can be a little unstable when one side is on jack and the other is on the ground. Sorry, no pics.
rhk109
'76 911 3.0 Webers
Old 11-25-2004, 06:10 PM
PeterTarga's Avatar
Is it save to put a 911SC 78 on 4 jack stands, is this stable like for a gearbox oil change?
What is the best way to jack it up, first on the rear then on the front, can you jack up the whole front in once, or must you jack up first the right and then the left side, to jack up the back in once no problem.
Peter
Old 11-26-2004, 12:55 PM
HarryD's Avatar
Peter
I sure hope so. I raised mine one side at a time at the factory jack points.
This is what I did for the Tranny Oil change on my '73.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-26-2004, 01:34 PM
PeterTarga's Avatar
Thanks Harry, good article.
Peter
Old 11-26-2004, 02:57 PM
PeterTarga's Avatar
I still have a question, i want to buy jack stands for mine 911SC, what is the ideal jack stand height and capacity (3ton - 6ton) ?
Regards,
Peter
Old 12-01-2004, 12:17 PM
Friend of Warren
Regards,
Peter
You really need two sets, get a 2 ton set that is easy to move around and has a lower minimum height and a second set, the 6 ton that are tall enough to put under the torsion bars for an engine drop. For the tall ones, try to find a set that can go up to at least 23"
Kurt V
Old 12-01-2004, 12:25 PM
These are reasonable or you can
try these for overkill .
I am going to go for overkill myself, but the choice is yours.
Mike
1986 930
Old 12-01-2004, 01:51 PM
Virginia Rocks!
VaSteve's Avatar
I got those 6 tonners last night for my engine drop. Mike, what the hell are you putting on yours? 2 911s???
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 12-01-2004, 04:55 PM
strupgolf's Avatar
Thanks for the hints. But my problem is I've got a very low front air dam and cant get a jack under it. Only from the front of the wheel can I get it under the car, and cant get it to the front of the torsion bars, only the back of them. Now what?
Old 12-02-2004, 06:37 PM
HarryD's Avatar
Another place for the front is behind the wheels where the floor pan turns up. Also, I forgot what year, but at some point Porsche put a flat plate in that location for the express purpose of placing a stand.
Randy Webb posted this picture showing the location:
I usually put mine right at the curve.
Harry
2020 MB E350 4Matic
Old 12-02-2004, 07:35 PM
randywebb's Avatar
The same thread with my original pic has a pic by Bill Verberg showing a buffer from JC Whitney witha cutout for the metal lip. They are cheap. Or you could make one out of a block of wood.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-02-2004, 10:18 PM
Kantry Member
oldE's Avatar
If you can't get a jack underneath because of ride height or spoilers, grab a couple of short(2 - 3 ft.) lengths of 2x6 and bevel the ends. Then use these as ramps on your garage floor to raise the car enough to get the jack in so you can then get the car onto the stands. Note: remember to put your ramps back under the tires before you lower the car. (Don't ask me why this comes to mind)
Les
Best
Les
Old 12-03-2004, 05:56 AM
strupgolf's Avatar
Thats right, I forgot that the ramps are an option. Thanks.
Old 12-03-2004, 05:20 PM
Noel's Avatar
I also sometimes use the factory jack to raise the front of my car just enough so I can get a jack under the front center of the car to raise the entire front. I usually place a long piece of wood on the cross bar just behind the front A/C condensor in front of the fuel tank and lift from there. THen stick jack stands under the front torsion bar covers.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 12-03-2004, 08:42 PM
