alf alf is offline
alf's Avatar
Stinky Heat caused by Dual out Dansk?
A previous post indicated that the shape/location of the the Dual out Dansk pipes caused exhaust to be sucked up by the fan and fed back into the heating system.
Anyone have this problem? I do have a stinky heat problem, does not really smell like burning oil, more like exhaust.
thanks
alf
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 12-04-2004, 04:07 PM
911mot's Avatar
I see from the link in your sig you have no tail, maybe thats something to do with it.
Or maybe your running very rich?
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 12-04-2004, 04:19 PM
alf alf is offline
alf's Avatar
I might very well be running rich, my exhaust smells "dense", how do i adjust that?
alf
88 Carrera Coupe
Pelican Since 2002
The Roach
Old 12-04-2004, 04:27 PM
alf alf is offline
alf's Avatar
Anyone else have this problem with their Dual Outs? Leaning out the mix will just mean that lean exhaust fumes are coming in the car...
alf
88 Carrera Coupe
Pelican Since 2002
The Roach
Old 12-05-2004, 08:09 PM
Send a message via AIM to fintstone
As close as the exhaust is to the engine fan that pulls in the air to be heated...I imagine that anytime one is not moving (in traffic), depending on wind conditions, that this would be a possible problem. It happens to me now and then..I have a single Dansk out..It is particularly noticeable if your car does not have a cat since the exhaust is high in carbon monoxide. I would make sure there were no large gaps in the engine coimpartment sheetmetal where exhaust gas might be sucked in through.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-05-2004, 10:47 PM
IROC's Avatar
I have a dual-out Dansk and don't have this problem. The "unique" smell to the heat is no different than it was with the factory exhaust (I now have SSIs...)
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 12-06-2004, 04:35 AM
dickster's Avatar
i do not have any issues with mine.
you either have a leak in the exhaust systems else the fumes are getting in somewhere they shouldn't.
be careful!
Rich
'86 coupe
"there you are"
Old 12-06-2004, 04:56 AM
alf alf is offline
alf's Avatar
Well i guess it s time to spend some quality time under the car changing 16 year old gaskets
thanks
alf
88 Carrera Coupe
Pelican Since 2002
The Roach
Old 12-06-2004, 01:46 PM
I hate to speculate that a maybe is a Heat Exchanger leak.
I've also read that a short tail pipe would "drag" fumes back into the heating system. This one guy confirmed the short pipe theory with a temporary extension and it was a bingo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-06-2004, 05:06 PM
RETIRED
Joe Bob's Avatar
I never go slow enuff for my exhaust to catch up....
2012 ML350 3.0 Turbo Diesel
Old 12-06-2004, 05:25 PM
mike.. that guy's prob happened at any speed. like the short tail pipe was alowing gases in the low psi envelope.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-06-2004, 05:29 PM
