Mobile Motec Mechanic? Van Nuys area
A buddy's car died after about 10 minutes on the freeway after leaving TRE's shop. It's happened a few times and has fired up after sitting for a while, but this time it seems a bit more permanent. I think it's running an M800.
Any leads on a mobile tech that can have a look? Hopefully there are some logs that can shed some light. The car is back at TRE currently. Thanks!
Matt B '73 911E |
If you can't find someone locally, having someone remote in can also help. I had a guy from MI set up a car I installed a Holley HP system and it worked great. You need a laptop and a wifi connection and be on hand to be the eyes and ears for the tuner.
i would suggest to go back to Davids shop.It must not be to far.playing with MFI could be tricky.I`m sure TRE would help him
Ivan
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Found a local Motec guy. He's working on it...
Matt B '73 911E |
