Any Tricks to Installing the left Front Cam Seal that Drives MFI Pump?
I'm about to install the seal on the very front left cam that drives the MFI pump.
Any tricks for years of leak free service? Thanks. Ian |
I have mfi cams in my Weber-equpped engine. I "repaired" a leaking cam seal with a machined piece that sealed and covered the area. Access to install this didn't require dropping the engine, but you may have to drop the engine for full R&R accessibility.
Hope this helps somewhat, Sherwood |
Install two seals; one on top of the other. Jim
| All times are GMT -8. The time now is 01:04 PM. |
