Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
I had duck for thanksgiving
One of my project completed over the long weekend was I got the ducktail primed and painted. Turned out okay, still need to polish the clear after it has had time to cure a few more days, and I've got to cut down a grill to fit.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 11-28-2004, 04:23 PM
OZCarrera3's Avatar
Looks great John!
I'm a big fan of the duck on the later model cars and have the same project to do over the Xmas break.
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 11-28-2004, 05:09 PM
Stahlwerks.com
jhelgesen's Avatar
Originally posted by OZCarrera3
Looks great John!
Check your grill size early, some are different, I need to find a earlier one or cut mine down.
John Helgesen
Old 11-29-2004, 05:12 AM
Moses's Avatar
Looks great. I like the cupII wheels too!
Old 11-29-2004, 06:46 AM
What type of tail? Fiber? What brand? I love it! Any installation problems worth mentioning? I saw some Fiber tails up close at the last show I went to and they ranged from OK to bad.
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 11-29-2004, 07:03 AM
Stahlwerks.com
jhelgesen's Avatar
I'd rate this tail as just okay, not great. Gap is a little big between the fenders, and I need to scope out a smaller deck grill, the black plastic one is too big. Don't know who the manufacturer is, picked it up used. Its fiberglass and I had to reinforce a few cracks, no biggie so far.
John Helgesen
Old 11-29-2004, 07:53 AM
Zeke's Avatar
I had goose once. What would a goose tail look like?
Old 11-29-2004, 08:28 AM
drag racing the short bus
dd74's Avatar
That's it! I'm flying south, like right now!
The Terror of Tiny Town
Old 11-29-2004, 08:38 AM
OZCarrera3's Avatar
John, I had the same issue with an SC grill that I was going to fit. I rang the guy who supplied the grill to me and he said that all grills are the same size. Having said this, he agreed to take my grill back and measure it against those from an earlier car and a 3.2 Carrera. I should find out today or tomorrow what his findings were.
The only other possibility is that the grill's are supposed to be raised (on mounts of some sort) that would make them sit flush with the surface of the tail rather than recessed, sitting down into the tail. Can anyone confirm or deny this?
Sheldon
'07 BMW 335i
Old 11-29-2004, 02:45 PM
I would rather be driving
jpnovak's Avatar
Looks great John. Now you need some RSR bumpers to match!
All the early, mid SC and Carrera grills are the same dimensions. They had various materials, finishes, and designs through the years. The grills typically install so the top edge of the grill is flush with the decklid. Sometimes, spacers are needed to accomplish this.
Old 11-29-2004, 02:48 PM
OZCarrera3's Avatar
Thanks Jaimie, seems my suspicions are correct.
Sheldon
'07 BMW 335i
Old 11-29-2004, 02:55 PM
Send a message via AIM to Oldporsche
Cool
Most of the ones I've seen used an SC plastic grill and have had the the corners modified with a Dremel. I believe that the original opening was modeled after the opening you will find on the early long hood cars. The early grill appears to be a little smaller.
David Duffield
Old 11-29-2004, 02:57 PM
Stahlwerks.com
jhelgesen's Avatar
There is probably a good 1/2 to 3/4 inch that needs to come off a plastic grill, so spacers aren't going to help. I've got an early split grill on the wall, but it was a hair to big also, the acorn nuts on the top and bottom hit the decklid. I think there is a size in between I have to find.
John Helgesen
Old 11-29-2004, 03:51 PM
OZCarrera3's Avatar
In retrospect, the aperture on my duck tail is tapered. Mine is only about 1/4 of an inch to big, so if I were to place some small spacers (as mentioned by jpnovak) between the grill and the mounting surface for the grill on the tail, I'm sure that would solve the issue.
John are you sure this is not the case for your as well?
Sheldon
'07 BMW 335i
Old 11-29-2004, 05:18 PM
Stahlwerks.com
jhelgesen's Avatar
Sheldon, got the ruler out tonight to double check, old decklid opening, 9", new ducktail opening 8.25". Spacers wouldn't help. If I can't locate a smaller grill, I can take the sander to a plastic one.
John Helgesen
Old 11-29-2004, 06:43 PM
efhughes3's Avatar
Spacers aren't part of the assembly on these, they are really rubber pads-maybe 1/8" or so thick. I just puit on a new TRG (built by Getty Design) duck, it fit really well, and accepted the stock grill without any issues.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 11-29-2004, 06:49 PM
OZCarrera3's Avatar
Well my 3.2 Carrera grill was delivered today and guess what, it is smaller than the SC unit and fits the ducktail perfectly! The 3.2 grill is also made of metal, rather than plastic which is a nice touch. It'll look fantatsic when its fitted.
Sheldon
'07 BMW 335i
Old 12-06-2004, 02:28 AM
how about a rear pic.. maybe with more light.
tia
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-06-2004, 04:29 AM
Stahlwerks.com
jhelgesen's Avatar
Ronin, I'll see what I can come up with, got the grill cut down and installed this weekend.
John Helgesen
Old 12-06-2004, 05:35 AM
