water leak inside my car
I have a water leak somewhere. When ever it rains, I get water building up on my floor board. The car can be parked and I will have a good size puddle. I can't seem to trace it anywhere. Has anyone else experienced that or know a particular area to look at that would cause it.
1978 911sc Slantnose
1995 Hummer H1 softtop
1997 Jeep Wrangler
2001 Lincoln Navigator
Old 12-09-2004, 09:17 AM
Still Doin Time
asphaltgambler's Avatar
Where in the car does the water pool??
Old 12-09-2004, 09:19 AM
primarily in the back floor board
1997 Jeep Wrangler
Old 12-09-2004, 09:20 AM
Still Doin Time
Does your car have a sunroof? When it's parked is it level?
Old 12-09-2004, 09:25 AM
Use your garden hose to trace the water in.
On my 69T, I had many leaks issues (fixed some) not all yet...getting close though. In regards, of the rear area I have faced the following:
- Rear quarter windows seals were old, and craked...got these replaced. (could go all the way down to the floor...follow the rotten/wet soundproofing)
- Rear window was leaky...got some pros to inject silicone all around. (this translate into rust on the rear seats seams)
- the car had been repainted 10 years ago, and door liners were not put back on...glued and taped some plastic sheet inside the doors. (the water will go directly to the floor under seats)
This is my experience...
I shall say that I have too much experience on that topic...especially when I go tell my wife ... "honey, you know what? I found another leak!"...fortunately, she loves the car too!
ZeFreds
1969 911T - Daily driver "La Titine"
Bought on the following condition from my wife "Do NOT let it sleep in the garage...you have to drive it EVERYDAY!"...I love my wife!
Old 12-09-2004, 09:33 AM
Quote: "- Rear quarter windows seals were old, and craked...got these replaced. (could go all the way down to the floor...follow the rotten/wet soundproofing)".
Ahhhh! That might be it. Mine are cracked pretty good on both sides. I was eventually going to replace these but I didn't know what that consisted of. It looked like the window and that were one unit. Did you do the work yourself or did you have it done?
1997 Jeep Wrangler
Old 12-09-2004, 09:57 AM
Glasgow 911SC's Avatar
After ages searching & sealing every gap I finally traced my leak to my doors. Despite having the plastic liner in place, water was still getting through a small gap. It would pool, in the door ledge (inside the seal. and overflow to the floor. I went crazy with bathroom sealant & now have a dry car.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 12-09-2004, 11:02 AM
Make sure you do the hose test first...before opening your wallet.
I did the change myself (fairly easy), but remember that I don't have the rigid rear quarterwindows, but the ones that open up. (Hope it is clear) I have no idea what it takes on the other type of windows...
Fred
ZeFreds
Old 12-09-2004, 11:14 AM
