Targa top Years
I wanted to bring this topic back to where it should be. It got in to the classified and the topic shouldn't be there.
Here is the posting
Targa Top year differences
There seems to be confusion as to what Targa tops fit what years.
Fitment years
Tops are not interchangeable except where stated, because body design and Targa top seals differences.
67-68 Thick three finger hinge frame, narrow side seal held with trim piece with five screws, two bare rear metal pins, hook latch, vinyl headliner of soft window and cloth headliner for hard window, fine grain vinyl covered. The soft widow frame was heaver. Tops are interchangeable.
69 Thin two finger hinge frame, narrow side seal held with trim piece with five screws, two bare rear pins, cloth headliner, fine grain vinyl covered, hook latch. Visually different than 67-68 but interchangeable. Narrow over the windshield seal.
70-73 Thin two finger hinge frame, wide side seal held with four screws going through rubber, two bare rear pins, cloth headliner, fine grain vinyl covered, hook latch. Start of thick over the windshield seal.
74-85 Thin two finger hinge, wide side seal held with four screws, three rear pins with plastic sleeve on out side pins, cloth headliner, coarse grain vinyl covered, hook latch. There is a slight difference in front frame design between 74-77 and 78-85 but they are interchangeable.
86-89 Thick three finger hinge frame, wide seal held with four screws going through rubber, three rear pins with plastic sleeve on out side pins, cloth headliner, coarse grain vinyl covered, roller latch. This will not fit later 90-94 cars, any attempted use leads to fly offs.
90-94 Thick three finger frame, narrow side seal no screw holes, heavy steel rain gutter, three rear pins with plastic sleeve on out side pins, cloth headliner, coarse grain vinyl, roller latch. Change in windshields pillar and very thick over the windshield seal makes this top stand alone form 86-89.
Dan Petchel
CarsincNJ.com
Targa top Restoration
Vintage parts
609 298 2277
carsinc@comcast.net
Old 12-06-2004, 08:05 AM
Thanks for info
I've wondered about the difference between years and this is an excellent reference now.
Thx
Old 12-06-2004, 08:15 AM
