The blower squeaks so I think I will remove and lubricate this weekend. Where exactly should I squirt the oil? Is their a lubrication hole like house heater fans have? Can I just spray the whole inside with dielectric grease or should I try to get turbine oil right into the shaft bearings?
John C 1988 911 Carrera coupe 2002 BMW 530 |
they're just about worn out when they squeel, so you might gain a little time. like week or so. the shaft rides in bushings, so you would have to pull the fan off and pull the armature out of the housing to get at both bushings.
Czar of C.R.A.P.
Do a search about blower motor replacement and you will find various articles about replacement. The original motor is no longer made and if you can find one probably $250.00. The system can be converted to a motor available from Dayton for under $50.00 total. You have to take the complete system apart to lube anyway you might as well replace.
.skillet to heater blower Here is how I did mine. Based on posts from other members
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
FWIW, I have one for sale. E me if interested.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
