-   -   '82 SC Brake return springs - arrgh!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/196147-82-sc-brake-return-springs-arrgh.html)
larkja 12-09-2004 03:16 PM
I have an '82 SC and just replaced the rear studs without taking off the hub. One of the pelican members recommended taking off the e-brake cable and feeding the new stud through the hole - it worked great.
Now the only problem I have is trying to replace the brake return spring into the holes in the e-brake shoes.
HELP!!!
Do any of you have any tricks to get this back in?
Thanks,
Jim
