-   -   How's it possible to tell if a part has been either bead-blasted or walnut blasted? (http://forums.pelicanparts.com/porsche-911-technical-forum/196207-hows-possible-tell-if-part-has-been-either-bead-blasted-walnut-blasted.html)
H.G.P. 12-09-2004 08:04 PM
How to tell the difference between the two?
Zeke 12-09-2004 08:08 PM
I think it would depend on what kind of part....
Porschekid962 12-09-2004 08:23 PM
mmmmmm no idea. glass bead media comes in different grit sizes, as far as shells who knows.
would it be a big difference to you if it was one or the other?
H.G.P. 12-09-2004 09:00 PM
Yes, I understand that pistons should not be bead-blasted in the ring land. So in evaluating a used piston that appearance is good, how would one make sure it had not been bead-blasted?
Porschekid962 12-09-2004 10:22 PM
wow, thats a big diff from glass media blastin. i just went over my alu. bike frame with the glass blaster at shool and it has a much more uniform, slightly shiny look to it.
H.G.P. 12-09-2004 10:45 PM
Is there a texture difference that can be felt to the touch also?
Willem Fick 12-10-2004 03:35 AM
Glass beads will leave a surface finish not too different from that of frosted glass in texture (smoother perhaps), whereas walnut blasting should leave the surface texture near to original.
Regards!
Willem Fick
