Diss Member
Quicksilver's Avatar
Keeping the flow attached where it is coming down the window should reduce drag but increase the lift. On the Evo I would expect the improved quality of airflow to the rear wing to end up with a net reduction of lift though.
In the late 80s I saw an airflow device that was kind of like reverse of a NACA duct but turned backwards. The front edge was the wide part and it protruded higher up into the airflow the farther back you went. The rear of it was an abrupt vertical cut off with an outline like the front of a NACA duct. These shapes were then placed in a row. It was patented and the guy who made it said it would keep the airflow attached around very aggressive corners. One way he was pushing to sell them was as strips to put on the front edge of semi trailers to keep the air attached from the front face to the top and sides of the trailer. They were very active at highway speed but they are quite a bit more aggressive in the airflow then a conventional vortex generator.
Those were about an inch high and spaced about out every couple inches. We were playing with the idea of putting the same shaped bumps in the floor of an intake runner to try and get the flow to turn towards the valve more efficiently. We couldn’t find a way to fab them and then get them to stay in place so we scrapped the idea.
Wayne
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-10-2004, 12:10 PM
Bill Verburg's Avatar
Reminds me of Riblets
Bill Verburg
Old 12-10-2004, 01:02 PM
That is a great website, I bookedmarked in in my "Aircraft" folder.
Perhaps I will find out if the Ford Tr-Motor's corrigated skin helped or hurt it's performance afterall.
1998 Chevy S-10 4x4 Pick-Up Truck, Razzle Dazzle Camo
Old 12-10-2004, 01:18 PM
I doubt it but stranger things have proven to be true
Bill Verburg
Old 12-10-2004, 01:20 PM
From the Riblets site....................
Also check out the "compliant" wall /skin section, very interesting.
Old 12-10-2004, 01:21 PM
As mentioned above, VG's are in fact for flow separation prevention. The small vorticees produced by VG's help reattach airflow and better the L/D ratio (drag reduction). They are more effective near stall speed.
Chris
Old 12-10-2004, 04:49 PM
randywebb's Avatar
re "compliant" wall /skin
Check out:
Kramer, M. O. 1960. Boundary layer stabilization by distributed damping. J. Amer. Soc. Naval Eng. 72: 25-33.
- very interesting article on dolphin blubber -- never heard from the guy again after he got those US Navy grants....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-10-2004, 04:59 PM
Semper drive!
rcecale's Avatar
Send a message via AIM to rcecale Send a message via MSN to rcecale Send a message via Yahoo to rcecale
Interesting stuff about vortex generators. Here's a bit more.
Shortly after the F/A-18 was introduced into the fleet, a serious flaw was discovered in the spars that supported the vertical stabilizers.
While troubleshooting a fuel leak, one of our airframes mechanics was removed a few of the skin panels at the base of one of the verticals. What he discovered was quite scary! I'm just estimating, but there are something like 10 or 12 (maybe a few more) spars that make up the framework for the vertical. The leading spar was cracked all the way through, and the following 3 or 4 had working cracks. This thing was headed for a definite failure.
Had these spars failed, the results could/would have been loss of controlled flight. After performing fleetwide inspections of these spars, Navy and Marine Corps wide, several more similar cracks were discovered. It seems the force of impact of the airstream was just too much for these things.
The fix? You can see in this picture. We called it a LEX Fence. The leading part of the wing that came forward along the fuselage was the LEX (Leading Edge Extension) This modification was applied to all F/A-18 Hornets in the fleet, the cracked/broken spars were repared or replaced and they never returned. Apparently these fences broke the airstream up enough to relieve the stress without causing a loss of control.
Just a little FYI...
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 02-28-2005, 06:01 AM
Is the LEX fence the modern form/version of the dorsal extension vertical stablizer spine of the B-17?
Production:
Prototype:
Old 02-28-2005, 06:27 AM
Me like track days
Craig 930 RS's Avatar
No, it is called a "tail root extension" and serves only to enhance yaw stability.
We designed one longer on the 737-300/400/500 for that purpose -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-28-2005, 06:29 AM
304065's Avatar
Fabbing some micro VG's out of aluminum stock wouldn't be difficult, nor would slicing the paint with a razor and adhering them above the rear window.
There's probably some airflow separation that results back there, as the tufts moving forward indicate-- there's a "burble" over the rear window. This is, I suppose, why the GT guys run aluminum plates to raise the wing up out of this turbulent layer.
At the end of the day, though, it's all a question of segment times.
Only place I can think this would be helpful would be in stock class racing, and you might get away with it by calling them "spoilers," but the "spoiler height" rule might get you.
Rather than slicing the paint I would prefer to make one fewer mistake per lap . . .
'66 911 #304065 Irischgruen
Ex-'88 Carrera (Sold 3/29/02)
Old 02-28-2005, 07:05 AM
Information Junky
island911's Avatar
hmmm .. looks more like tripping the boundary layer (like golf-ball Dimples) than what would be called a Vortex-Generator.
Thou' I suppose sales will be better when associated to a jet, rather than a little white game-ball.
Disclaimer: the above was 2˘ worth.
Old 02-28-2005, 07:42 AM
Right, I knew they were different - still a "fix" is a "fix".
Cool F-18 links talking about LEX fences.
http://www.nas.nasa.gov/Pubs/TechSums/9394/014_nas.html
This one is more general, yet better - same source though.
http://www.aerospaceweb.org/question/planes/q0176.shtml
They reinforced the vertical stablizers while they were at it.
Old 02-28-2005, 07:58 AM
Originally posted by island911
[B]hmmm .. looks more like tripping the boundary layer (like golf-ball Dimples) than what would be called a Vortex-Generator.
Here is an article which talks about both - some very good diagrams and pictures too.
http://www.aerospaceweb.org/question/aerodynamics/q0215.shtml
Old 02-28-2005, 08:17 AM
Information Junky
island911's Avatar
. . . kach, good find; that's an excellent web page, on the subject.
key pharagraph:
"However, there do exist other types of devices commonly used on wings that create a similar effect to the dimples used on golf balls. Though these wing devices also create turbulence in order to delay flow separation, the purpose is not to decrease drag but to increase lift. One of the most popular of these devices is the vortex generator."
Old 02-28-2005, 08:31 AM
I can't imagine that the vortex generator increases lift in and of itself, but rather by enabling better airflow over the wing.
Old 02-28-2005, 08:35 AM
Super Moderator
cstreit's Avatar
We actually expirimented with these on our model airplanes. They were referred to as "turbulator strips" in my conversations. Did help stall characteristics on the small planes, esepcially on stall-prone ones like the Extra 300.. ...but not very much...
Chris
2001 GT3 Cup - "Pepin"
1999 Spec Miata
1996 993 RS Replica
2010 Harley “48”
2013 Honda 250 CRF
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-28-2005, 08:48 AM
