Me like track days
Craig 930 RS's Avatar
Question Shift knob for WEVO shifter?
Will nearly any of the MOMO shift knobs fit the WEVO shifter?
Thinking of this one:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-14-2004, 01:35 PM
Britain Smith's Avatar
I know that the orginal look shifter that he sells will fit a stock shifter knob so if this is the same I would assume that it also fits.
I like the look of that shift knob also.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 12-14-2004, 01:42 PM
jakermc's Avatar
You need to buy the adapter from Wevo to fit a Momo knob. Thats what I did and used a knob similar to the one you pictured here. Big difference before and after the adapter is that the position of the knob is much higher using the adapter. I liked it better since my car is a track car and it puts the knob closer to me.
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 12-15-2004, 05:18 AM
Me like track days
With my seats the adapter might not work - interference possibly - does the MOMO knob still work 'solidly' on the WEVO shifter without the adapter?
THX
Old 12-15-2004, 09:31 AM
Craig,
The OWOW knobs can not be installed directly onto the billet shift levers, the Ø we selected for the installation of the WEVO knob is too small for the OWOW knob.
The adapter provides a correct Ø to install the knob you show.
As Britain says, the OWOW knob will fit directly to the WEVO Classic levers as these replicate the O.E. knob fitment.
Regards
Hayden
Old 12-15-2004, 12:15 PM
