Lighted key head retrofit
Can a lighted key head be retrofited to older key styles. Or better yet is the new key able to be cut to an older key style. The key is for a '69 911. I'm tired of trying to find the key hole in the dark. No jokes please
Has anyone tried this? Thanks, Sam
Sam Gonzales '69 912 2.0 -6 power |
I think so- at least it worked w/ my SC. Any locksmith will cut a copy- you just need to take in your old key & the new blank & presto- no more feeling around blindly for the slot.
You cannot take the metal key insert out of the black or red plastic "hoop" holders and use it in the lighted key heads - even if you cut them down with a dremel it would not fit.
If you mean something else maybe you can give some more info...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
You could just get her drunk and leave the lights on...
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
yea you definitely need the correct blank for the new 'head'.
RETIRED
I bought a modern blank....the lighted head....ground my old key head off and matched it to the blank.....worked great. Except the Fuch ing Porsche crest fell of off the new key head....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
are you saying you added the U slot and the horn 'hook' onto it? Incredible amount of work if so.
RETIRED
yup....just a little filing and a dremel. Pi$$ed me off when they told me it wouldn't work....I hate that....telling me I can't do something....
I like the dremel idea. I have a couple extra keys to try it with. My key is not a hoop key it has an oval head. Also, I take it that a key blank that is made for the lighted key head can be cut to work in a '69 911. Meaning there isn't a fundamental difference between the new and old key shapes. Please correct me if I'm wrong. Thanks, Sam
RETIRED
I did it with an 83 key....it looked like the keys that I have for my 70s era 914....dunno what yours looks like.
I took my '74 key down to the dealer and asked them to make me a lighted one to match. They did and it works swell. It was about the same price cut as the blanks on ebay.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Bird. It's the word...
Sammy, sounds like an excellent project as I have a 69 and a lighted key head, but no blank. Post plenty of pictures!
John Forcier Current: 68L 2.0 Hotrod - build underway |
