-   -   Shrink wrap with moisture absorber? (http://forums.pelicanparts.com/porsche-911-technical-forum/196336-shrink-wrap-moisture-absorber.html)
Chris Lovell 12-10-2004 05:23 PM
I am considering wrapping the 911s (like boats in shrink wrap) with a bucket of "Dry Out" chemical dehumifier wrapped inside. Can anyone tell me why this is a bad idea or won't work to keep the car dry? I can't move to Santa Fe or drive the 911s in the snow very well (plowing stinks around here and salt is in use). So, the cars are tucked away for the winter and I would like to keep the condensation at bay.
Thanks.
toolman 12-11-2004 08:07 AM
I put mine in a "car jacket" that came with desicant. This is my second year using it and it works great. Do a google search on car jacket.
cgarr 12-11-2004 09:20 AM
I would not wrap it tite like a boat. I have seen the plastic or whatever they make the stuff out of release something that lift and crack the paints on autos. A fabric type cover may be the best
cg
randywebb 12-11-2004 11:40 AM
Many of those things use vinyl - it outgasses vinyl chloride which is really bad, and then that also turns into HCl - hydrochloric acid - also bad! This stuff is known to photographers who store negs and slides -- they won't use it and pay extra for a different type of plastic.
See the prev. threads on this - I think we decide you'd be ok with a vinyl "hoop tent" type one with a ventilating fan.
Or just use a flannel car cover, with a water shedding one over it.
Chris Lovell 12-11-2004 07:23 PM
I am actually considering a blue poly tarp to "envelope the car" over a Noah cover. This would help keep the vermin out and, with some humidity absorber, pretty dry as well. Think there would be any outgassing or conversion with this setup? Thanks.
randywebb 12-11-2004 07:58 PM
Sure there will be outgassing - but not the kind you need to worry about - and it will be ventilated well. Don't think the crystals will work to reduce humidity - big volume and not really sealed.
Nothing beats a garage tho.
Chris Lovell 12-11-2004 08:11 PM
Thanks Randy and all. I'll give this a shot and let you know what happens.
The Chef 12-12-2004 12:35 AM
LOL LOL LOL LOL
cgarr 12-12-2004 05:14 AM
I think they started putting warnings on those blue poly tarps because of the problems with cracking your paint, something like "not to be used for autos or painted surfaces"
cg
Chris Lovell 12-12-2004 02:31 PM
They do have that warning but I am assuming it is warning against the poly tarp making direct contact with the paint. In may case, the poly is over a car cover.
I am pretty sure this should be okay. Anyone have any experience with problems doing this poly tarp "sealing" technique?
jthwan22 12-12-2004 06:47 PM
this is easier for $150
http://www.autosportcatalog.com/index.cfm?fa=p&pid=2400
Chris Lovell 12-12-2004 08:36 PM
Yep. That's it exactly.
My poly tarp and clothes pin alternative is similar .. and way uglier.
