Fuel Pump 911SC -- Aftermarket Replacements
Can anyone provide a link to specs (or the specs) for the fuel pump on my 1979 911SC, e.g., min psi, flow rate, etc. I want to research the possibility of buying an aftermarket replacement for the Bosch. Does anyone have any advice. Thank you, Duane Duclaux
'79 911SC Targa -- "BLUVUDU"
'83 930 Coupe -- "TURBAUX"
Old 12-13-2004, 11:30 AM
How did you figure out it was the pump and not the fuel relay or other issue?
Old 12-13-2004, 11:33 AM
Tested the pump directly with 12v source. That test backfed the relay (its whistling indicated the relay was operational). Pulled the pump, hit it with 12v -- could feel a "bump" inside the pump -- it wanted to turn but couldn't. Confirmed the pump was bad when I disassembled it -- it had been sitting up for several years and old fuel seemed to have varnished one pin in the impeller frozen.
Old 12-13-2004, 11:37 AM
i've never heard of an aftermarket, non-bosch pump.
206 637 4071
Old 12-13-2004, 11:41 AM
Thank you, I still have to dig into my problem. The car has been sitting for nearly a month.
Old 12-13-2004, 11:42 AM
MAGA
Tim Hancock's Avatar
I believe there is a Piersburg or something like that, pump out there.
A while back I was looking for a replacement for my daughters old 924 and it seems I came across the name Piersburg as a replacement. I ended up with a '79 911 Bosch pump which is what the superceded pump is now for the old 924's. I wish I could remember more but try searching the web for Piersburg (it may have been in a Performance Products catalog).
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 12-13-2004, 11:52 AM
Senior Member
Superman's Avatar
I'm probably Pelican's reigning champion cheapskate, and I probably would not be interested in using an aftermarket fuel pump. Those things work HARD, and I don't like walking away from my car on a deserted stretch of road in the middle of the night while it's raining.
Mocha 1978 911SC. "Coco"
Old 12-13-2004, 01:33 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Take a look at this previous thread posted by Jim Sims.
Cooling the jets on Nine-mile Hill
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 12-13-2004, 01:46 PM
Send a message via AIM to Oldporsche
Cool
Many years ago, I tried to start my 930 which had been sitting a long time. I found that the front pump was frozen. I soaked it in carb cleaner and hit it with 10 vts once in a while. After a couple of days of soaking and rinsing it out, I pulsed it one more time and it worked!
David Duffield
Old 12-13-2004, 01:54 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
FWIW, I've been running an universal Bosch pump, PN 0 580 254 909 (got mine for $150 when I was in Maryland) for about 12K miles on my '78 motor without problems. Pelican may be able to get it for you?
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 12-13-2004, 02:16 PM
Gordo2's Avatar
Walbro Makes One
I have recommended this item to Pelican. Walbro makes an in-line pump that is a one for one no brainer install. Around $150.
I've had one on my '83 for around 6 months.
Good Luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 12-13-2004, 05:25 PM
