Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Sudden problem with 84 911
Normally, car starts instantly as soon as you turn the key, regardless of the temp.
Now, it cranks for 2 or 3 seconds before firing, and if you don't hold it the full time, it will die.
When I lag it in 2nd gear or even in first (and by lag I mean, slowly and gently press the gas) it will buck on me big time, usually just once. Won't stall, but it will buck or seem to cut out. This is completely random. It doesn't happen consistently, but does seem to happen only when i don't have the full throttle open. If I'm racing off, it doesn't happen.
Before this problem, I had hooked up the oil overfill hose: I had disconnected it and extra oil did squirt out over the engine bay making me think I had a leak. But that has been hooked up. To do so, I had to take off the AFM and screw connector back into the air filter cone that would accept the over fill hose. I checked the AFM connection, and it's fine.
Since this problem, yesterday, I changed the fuel filter which was at least 2 years old, and I changed the distributor cap and cleaned the rotor. Checked all of the connections to the distributor, and they're all just peachy. But it still, even after being warmed up, won't start instantly. It wants to keep cranking and doesn't want to effin start.
Also, I checked the coil connections, and they're all clean and perfect.
Any ideas about where to look?
98% of my driving time, it's still running good, but there is something clearly amiss.
Bad gas?
-kb-
Old 12-12-2004, 07:53 AM
kqw kqw is offline
When was the last time you changed out the DME relay?
The Fox
Carrera
Old 12-12-2004, 09:11 AM
Probably 5 years ago.
-kb-
Old 12-12-2004, 09:16 AM
kqw kqw is offline
Do you have a spare one to replace it or a fellow pelicanite that will loan you one?
The Fox
Carrera
Old 12-12-2004, 09:22 AM
3.2 CAB's Avatar
Pressure regulator? Sounds like it is loosing its fuel pressure when shut down.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-12-2004, 10:04 AM
I have a spare DME around I think. Pressure regulator. Okay, I'll check it in the manual. I can swap out a DME relay and see if it makes a difference.
-kb-
Old 12-12-2004, 10:51 AM
Driving member
jester911's Avatar
Kurt, I know you said you checked or changed the distributor cap and rotor but the description sounds alot like the symptoms I had recently.
I removed the dizzy cap and found it to be so bad at the top I am not really sure how the thing was getting spark as well as it was.
A new cap fixed the problem.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 12-12-2004, 12:56 PM
Thx...yeah, I thought that too. It acts like it's not getting spark, but after making the changes I made, it's got to be a problem with not getting gas....we'll see when I investigate the pressure regulator.
-kb-
Old 12-12-2004, 01:11 PM
