-   -   Calling all grease experts... (http://forums.pelicanparts.com/porsche-911-technical-forum/196404-calling-all-grease-experts.html)
cowtown 12-11-2004 01:04 PM
I'm getting ready to do a clutch/flywheel upgrade on my '95 993, and I'm wondering what type of grease would be best to use on the guide tube, pilot bearing, and throwout bearing.
I see Warren in the past said he uses Moly EP, which is good enough for me.
So, should I order some Swepco 101, or would one of these (which I have sitting on my shelf already) be OK:
1 - Valvoline Synpower grease - for CVs, bearings etc. "moly-fortified".
2 - CRC Industries Sta-Lube EP Moly CV Grease
I'm probably overthinking this, but I want to be sure I get it right the first time.
Thanks!
Colin
rcwaldo 12-11-2004 01:10 PM
Any heavy grease with molybdenum will be fine. Remember less is more:)
Chris
dean 12-11-2004 03:00 PM
Hey Colin,
I don't know what tranny you have but if it has the vertical shaft in the bellhousing you might want to take it apart and clean the old grease out and relube. That makes a huge diff in the clutch feel.
Dean
RoninLB 12-11-2004 03:31 PM
I believe JW posted some dealer high temp grease for the throwout brg/tranny shaft.
RoninLB 12-11-2004 03:43 PM
JW says,
" porsche sells optimoly high pressure grease #000.043.024.00. it's for things like pilot bearings and clutch cross-shaft bearings that may never see grease again."
Britwrench 12-11-2004 03:47 PM
Use the Porsche grease. Never grease the release bearing guide tube if using the factory clutch release bearing. The bearing will have a plastic inner liner with a split in it, grease causes stickiness. This is as the factory technical bulletin. Always grease the end of the slave cylinder rod, use an anti-seize or similar grease.
Quicksilver 12-12-2004 02:27 AM
Bosch distributer grease. Very high temperature and it stays in place at high temperature. Pelican lists it.
Wayne
dean 12-12-2004 05:45 AM
I should really learn to read someday:rolleyes:
Good luck on the clutch
Dean
randywebb 12-12-2004 12:15 PM
BTW, Grady has neat little trick - cut a groove in the clutch tube to let any leaks drain out. Search on my name, Grady Clay and transmission and (probably) 901.
cowtown 12-12-2004 12:48 PM
Thanks everyone. I guess I'll get the special Porsche grease.
I'm upgrading to the RS/Lightweight single-mass flywheel, so it's all factory parts.
Britwrench, you saved me from making a mistake on the guide tube - thanks for posting.
