-   -   source for turbo "heat blanket" (http://forums.pelicanparts.com/porsche-911-technical-forum/196418-source-turbo-heat-blanket.html)
raceman 12-11-2004 01:06 PM
l`ve got a glass rear bumper,any heat from my new turbo system that l can contain is a good thing.Have any of you seen the turbo blankets that are fitted onto the hot side of the turbo? l know about the heat wrap,l`ll need that too but the cute little blankies,that`s what l`m really after.any help appreciated..
Bill Verburg 12-11-2004 01:13 PM
Heat Shields
5axis 12-11-2004 02:02 PM
Here is what I am running on mine.. plenty of material to screw it up and do it over if required
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4782&prmenbr=361
89turbocabmike 12-11-2004 03:40 PM
Are there any down sides to wrapping the turbo?
350HP930 12-11-2004 03:45 PM
A hotter turbo is one of them.
Since radiative heat is your biggest worry you could buy some thin sheet aluminum and place a shield somewhere between the turbo and bumper.
That way the bumper is protected and the turbine housing can still shed heat too.
5axis 12-11-2004 04:28 PM
I make the time to let her cool down before shutdown.. listen to song on the radio or a couple of Ramones tunes on disk. SmileWavy
sammyg2 12-11-2004 05:01 PM
Try turbo city, www.turbocity.com
they might have what you need.
RarlyL8 12-11-2004 05:04 PM
I run a fiberglass bumper also -- but do not have a heat planket on the turbo. I put one on the inside of the BUMPER. That way I know it will never be in danger from the heat. There is a large air barier between the turbo, muffler, and bumper blanket that helps as well.
