Woz Woz is offline
Woz's Avatar
Sound Insulation
Hello,
I'm considering replacing the tired old carpets in my 911. Whilst they're out I'm also thinking of adding some under-carpet sound-insulation. Do you have any recommendations on a good product, ideally one that is not prone to condensation build-up?
Thanks!
Old 04-03-2005, 07:14 AM
randywebb's Avatar
I would use Quick Coat or Kote and then some light wt. matting below the carpet.
Many long threads on this - a search will find a stupifying number. Use the term deadener or deaden not just insulation.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-03-2005, 11:09 AM
Sonic dB's Avatar
I did my whole car with lightweight soundproofing sheets that I purchased from Pep Boys for $19.95 per roll. 1.5 rolls did the whole car. Buy an adhesive spray too. It worked well and deadened the sound from the road by about 35%.
Old 04-03-2005, 12:13 PM
North's Avatar
I'm in the process of putting in the B-quiet 'extreme' sound deadener that replaced 'brown bread'. I am also putting in their L-comp and finally a new carpet set from appbiz via our host.
North
70T Targa
03 Liberty
05 Q-cab 3500 cummins
03 Q-cab 3500 cummins
93 Cherokee - bush jeep
03 and 04 Yamaha Kodiaks 2 of each
00 and 04 Ski-doo Tundras - bush sleds
Old 04-03-2005, 07:59 PM
I second the Lcomp... used strategically. I covered the rear deck before putting the RS set in.
It brought my car from "too loud to drive at all without earplugs" to "tolerable for short drives without earplugs". Additonally, I can actually talk to a passenger without shouting.
1968 911L
2004 Dodge Dakota SLT Plus
Old 04-04-2005, 04:50 AM
Install425's Avatar
Rob,
88 911 Turbo
Old 04-04-2005, 05:20 AM
strep's Avatar
Fat mat on Ebay is what I used. Very easy to work with.l
Old 04-04-2005, 06:53 AM
