How to test if a Heat Exchanger is leaking?
Is there a way to check for a HE leak?
alf |
You can generally smell the exhaust in the cabin when you have the heat on. Or you can get a CO detector if you want to get more scientific.
Go for a long drive with the windows rolled up and the heat on, and see if you fall asleep?
Get a CO monitor? (probably safer than the above test) |
| All times are GMT -8. The time now is 03:12 AM. |
