Humidity and painting
Hi,
I am getting ready to paint but am concerned that it is a bit drizzly outside, is that ok? The garage is closed and heated but no dehumidifier.
Thank,
Old 05-01-2005, 09:07 AM
notmytarga's Avatar
Humidity will have it's worst effects on your compressed air supply and paint gun. Use a filter/dryer/water trap and finish off the air with a new hose-end filter at the gun. Empty accumulated water in your compressor tank often.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 05-01-2005, 09:12 AM
abit off center
cgarr's Avatar
I would try to wait a bit for nice weather, I see your in MA, if anything like MI you may have to wait a lot!! , moisture is bad bad bad, since its in a garage be carefull about tree pollen this time of the year too! I like to paint in the fall or winter if you can heat your booth, Are you doing the complete car or just some parts?
Craig
______________________
Craig
G2Performance
Old 05-01-2005, 11:06 AM
