Valances & door seals
I believe these are called side embellishers or vallances.
Is there supposed to be a rubber "strip" between the body and the vallances? If so, part number? Also, I'm having trouble locating the proper door seals for a 1976 targa. Part number? Thanks. |
Friend of Warren
See if this helps: Seals and Weatherstrips Coupe and Targa
Kurt V No more Porsches, but a revolving number of motorcycles. |
Rocker panel rubber should be part number 930 559 103 01. Door seal numbers are as follows: left door 911 531 095 40 right door 911 531 096 40
