Me like track days
Craig 930 RS's Avatar
Question GP white = dingy trunk and engine compartment?
My euro 79SC GP White chassis has a brown dingy tint to it that is not removable - both in the engine compartment and the trunk.
Not the glued areas, either.......
Ideas welcome as to what this is --
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-14-2004, 02:09 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
have you tried SimpleGreen? That stuff cleans my GP White like no other.
'75 911S 3.0L
'75 914 in progress
'67 912R-STi
'99 LR Disco 2
Old 12-14-2004, 03:26 PM
david914's Avatar
Cosmoline. Not sure what is best for removal, but someone here will know!
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 12-14-2004, 04:23 PM
Me like track days
Thanks - I tried Simple Green in the engine compartment when the 3.0 was out and we were working on installing the 3.6......it didn't touch it!
hIs this color 'normal' for a GP WHite car?
Old 12-14-2004, 07:28 PM
Perhaps you can try a polishing compound in an inconspicuous spot. Start with fine grit and work your way up.
Warren & Ron, may you rest in Peace.
Old 12-14-2004, 07:30 PM
Gordo2's Avatar
Same But On Metalic Slate Blue
Craig,
Sounds the same as mine. I thought mine was just due to a crappy respray that went on the car at some point, but your post sounds similar. Mine was discolored on the lid and upper rear fenders.
I got a new tail and had it painted the original color. It actually matched the paint pretty well except against the discolored parts of the fenders ...
Oddly enough the fenders look good wet but when it dries out it the "smoked" look reappears. I've tried all sorts of waxes with no joy.
If you find something that cleans it up let me know.
Thanks, Gordo
Don Gordon "Gordo"
'83 911SC Targa
'87 FJ-60 TLC
Old 12-14-2004, 08:14 PM
The bmws recieved the cosmoline too. Its like a vaseline they put on when the cars are coming over on ships. Simple green worked on my bimmer. So I dunno?
Old 12-14-2004, 08:29 PM
MovOvr1's Avatar
I have heard (but have not tried since I haven't the problem) that Wuths Citrus degreaser will work with it with a stiff bristle brush (not metal) and won't harm the paint. You may have to go over it several times or bathe the area to let it soak in a little bit. The people over at the BMW board always suggest it.
bRian
Brian
BLK 79-930
Old 12-15-2004, 08:09 AM
Could just be built up crap? What about a clay bar? Or the polishing compound suggestion, moving up in grit as you test?
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 12-15-2004, 08:58 AM
I would rather be driving
jpnovak's Avatar
Mineral spirits should take it right off and not damage the paint. Wipe clean with dry towel when finished.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 12-15-2004, 09:16 AM
kilodawg's Avatar
Diagnosis is very important but if it in fact is cosmoline ON the paint the Purple Power type of cleaners available at WM WILL remove it. Not sure what effect it wil have on the paint though so check it out carefully.
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 12-15-2004, 09:19 AM
Me like track days
Will do guys. It looks like a smoker lived in the trunk....
Old 12-15-2004, 09:35 AM
DP935 member
kycarguy 935's Avatar
If its cosmoline it can be removed with kerosene. Im not sure if kerosene will hurt the paint there but maybe test a small area first. It works great on removing cosmoline on suspension parts to.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 12-15-2004, 09:40 AM
