key blank in lighted head
Is there a way to remove the metal key blank from the black lighted key heads? I bought one on eBay (used) but now it looks like there is no way to remove the metal part (it can't be cut because it is used - i.e. already cut for some car).
The plastic head part seems to be molded around the metal, and I can't figure out how to get it apart.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
If you take the battery out, you should be able to get to the end of the blank from the inside. I believe there is a tab in there that you can lift and it should come out.
oops, maybe thats why mine didn't go back together so well.
Tim 1983 930 w/ goodies Last edited by Slant930; 12-15-2004 at 11:06 AM.. |
Randy--
on the side of the key head there is a small locking tab, which you need to depress using a small screwdriver. Once released, the head comes apart. Careful - there are many small parts. IIRC, I don't think removing the battery gets you access to the key blank. I don't have my key handy - its on a separate key ring at home.
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
Hmmm.. I'm not understanding what tab and what depress means. IF you take the battery "lid" off then on the RH side is a small spring with a black plastic tab below it (close to the metal keyed insert part). It does not depress by pushing down on it, but if I stab it with a sharp blade I can push it diagonally upwards. But that doesn't seem to do anything. ????
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 12-15-2004 at 12:23 PM.. |
Randy,
If you push it far enough back it will finally pull a little tab out of a slot in the metal key head and release it. I used a sharp tool (like an awl) and stabbed the plastic part a little to pull it back. It has to be 101% retracted to release the head. RA
1989 Carrera Targa 1986 944 Turbo (totaled by trash truck) |
Here's a picture of the key blank, itself:
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports |
The spring-loaded latch drops into that V on the bottom left edge. On mine, I was able to push the blank into the housing without opening it after getting the key cut.
Help me understand....
You bought a "used" key on Ebay??? OOOOOK
The Fox Carrera |
Make Bruins Great Again
Maybe thinks the key can't be cut without the blank taken out.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
although it's for the switchblade remote, the "fixing" method is the same.
Look at the third picture down here" http://p-car.com/diy/key/
Clive. ******** GRMN XTC is a '95 993 Cab. ![]() Guards Red/Cashmere |
- Yes, it was quite cheap too - gives me the nice head rather than the plastic hoop.
Gott in Himmel!!
Well, I finally got it out - had to use a vice as a third hand and a 90o sharp pick.... No wonder those guys started two world wars... Thanks for all your help!
