randywebb's Avatar
washers for the engine and trans. mounts
I was trolling thru magazines for light wt. tidbits and found this:
In Nov. 1977, PAG said to install the big washers for the engine and trans. mounts with the concavity facing the rubber mounts. But, if rumbling noise is present, reverse them.
from Excellence #125, p. 20 - Dec. 2003 (that the BB2 and C-GT issue)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-20-2004, 03:12 PM
jpahemi's Avatar
Randy:
I found the early cars had them facing away from the mount and the 83-89 cars facing the rubber mount. I thought it was used to protect the rubber mount.
Regards,
J.P.
Old 12-20-2004, 03:22 PM
I just removed my trans mount on my '76 and the washer was dished away from the rubber.
www.exeterautosupply.com
1976 911S Targa
Old 12-20-2004, 03:57 PM
randywebb's Avatar
Yes, before that they were installed concave side facing the rubber. But PAG changed it as per above.
There must have been a TSB on it if BA put it in his column. Someboyd with the binder set of these things could look it up.
We had a long discussion thread on this some months ago.
Anyway, now we know what PAG thinks -- and why they think so.
Old 12-20-2004, 05:23 PM
jpahemi's Avatar
Randy:
What do you think is the best application; noise or rumble aside.
J.P.
Old 12-20-2004, 05:40 PM
randywebb's Avatar
Dunno. But I put mine on the 'new' way. It may not matter much. I'd go with the Wevo ones if they weren't so spendy (and - as usual - I bought brand new ones just before a better product came out... I've done this 7 or 8 ties now!)
Old 12-20-2004, 06:00 PM
