poorshe911's Avatar
warm-up regulator troubleshooting
I have a 1983SC that has a hesitation problem. It's pretty consistant so I feel that it is fuel problem. The problem is very noticeable cruising around 2500 rpm's. I've replace the fuel filter, air cleaner, plugs, cap & rotor. The car starts fine and seems to idle a little rough and at a slightly lower rpm than usual.
How can I tell if the warm-up regulator is functioning properly and not offering a restriction to the fuel supply?
Otherwise, the car is in pristine condition with about 76K miles.
Any other ideas?
The car is in storage now but I can still get at the engine to try things.
Thanks for any help.
Michael
Old 12-18-2004, 04:38 PM
AFJuvat's Avatar
Usually when the WUR goes bad, the symptoms include a poor idle and the inability to really give the car any gas until it has warmed up (WUR leans the car out too much).
Function is normally checked with a fuel pressure gauge between the fuel distributor and the WUR. On a cold engine, the fuel pressure going to the WUR rises at a steady rate (see diagram below)
You will want to test this with the pressure gauges rather than by swapping parts - the WUR is pretty expensive.
A few other things to check:
Frequency valve: behind the airbox, when the car is running, you should be able to feel this valve vibrate.
Pressure regulator in fuel distributor: O-rings fail.
sensor plate warped\excessively dirty\out of adjustment.
Here is the sheet with some of the fuel pressure values.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-18-2004, 05:10 PM
makaio's Avatar
Re: warm-up regulator troubleshooting
As AFJuvat said, you need to do a fuel pressure test to trully tell if your warm-up regulator is bad. You can throw parts at a CIS car all day long and not solve the problem, if you don't do a fuel pressure test.
Old 12-18-2004, 05:32 PM
1. Agree with the others that you start with a complete pressure test.
2. If 1 OK, set the CO properly using a gauge.
3. Then, and only then, start changing parts.
Old 12-18-2004, 09:28 PM
beamonk's Avatar
Send a message via AIM to beamonk
Try checking your vaccum advance on the distributor.
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 12-18-2004, 09:48 PM
I wouldn't rule out an ignition related problem just yet.
A consistent hesitation is just as likely ignition related.
-Joe
Old 12-19-2004, 08:17 AM
