I am trying to change my rear spring plates to the sway-away adjustable spring plates.
Is there any trick to removing the old spring plates from the stock torsion bars? Is there some kind of puller I need to use. If I have no luck and cut it off and go ahead and purchase new rear torsion bars, what size is best to use without affecting the handling? My front torsion bars are stock size. |
I had to cut my torsion bars in half to remove them because they had rusted to the plates, my grinder and a cut off wheel did the trick. What are your intentions for ride characteristics? Is gonna be tracked or strictly street? Larger bars and adjustable plates are great but should complement your suspension. What about your sway bars, your shocks/struts, using poly-bronze bushings, camber plates and so forth? I'm doing major work to my '71T and going thru all this now. I went with a complete suspension upgrade and I do mean complete. So 1st determine what the car is gonna be used for, how much do you want to spend and plan on using larger bars with other upgrades for best results. Just my .02 worth, but I did a lot of homework before I jumped in, it is expensive but well worth it so I didn't spend money to achieve an unfavorable result.
1977 911 with major upgrades! |
Kantry Member
I just used a 2-armed puller. lots of liquid wrench and a bit of patience.
Les
"I'd much rather signal a virtue than scream a vice." Michael Coren |
Friend of Warren
When I have a torsion bar stuck in the plate I just drill a 3/16" hole in the end of the torsion bar cover and use a hammer and punch to drive the bar out.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thank You for the responses
My car will mainly used for street use, possibly once or twice to the track or autoX. I was not planning on doing a full suspension mod. I was just going to lower the car and place poly sway bar bushings. PS: If it is really stuck and only choice is to cut it off and get new torsion bars, which size bar is best to buy that closest to stock set-up? the reason is my front is completely stock. |
Nobody
i believe the stock is 22mm. the next size stock bar would be from an SC at 24mm. you should be able to pick up a pair of good used bars for $50 or less. i used the same method as Kurt and replaced mine with rear SC Tbars and stock 18.8mm up front.
Used User
I think it's 23mm. I have some stock ones if you're interested. Email me.
My FB page: www.facebook.com/oddjobfix Antique and Collectibles Repair and Restoration On YouTube at "oddjobfix" |
Nobody
memory is failing me as i did the entire susp at once, the sway-away spring plate bushings may need to be lathed. i might be confusing having my front poly a-arm bushings lathed. i would also find out if chuck moreland makes the spring plate bushings. also a good time to replace the 4 rear sway bar bushings as well as the trailing arm bushings.
devalued member
i clamped vise grips to the torsion bar right at the spring plate and using as flat bar pried the t-bar from the spring plate. lots of liquid wrench! since you will be swaping out spring plates, kurts method above is good too. i reused my spring plate so i did not want to drill the spring plate dust cover.
i too have a set of stock SC 18 and 24 MM t-bars here in the bay area. as mentioned above $50 takes all four. they came off a car w/ 75K miles. PM or email if interested, i am in sunnyvale.
75S slick-lid webered, early n spicy 3.oL hotrod wanabe 78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ (build thread >) http://forums.pelicanparts.com/california-southwest-us-az-nv/443725-plunge.html |
What is the stock size front t-bar from my 1971 911T?
Worst case scenario I may have to pick those t-bars for $50.00, if I end up cutting my stock t-bars. I will keep you posted. Bob, Those red bushings that came with the sway away, do they fit properly or do i have to shave them down? |
Nobody
yeah - the visual is coming back to me now. i did have them lathed cause they were extremely tight!
How much did have them lathe down?
where did you have them done? |
devalued member
here is your stock sized bars
http://pelicanparts.com/techarticles/911_torsion_bars/911_torsion_bars.htm
How much clearance do you want to create when you "lathe"? Don't you want the moving interface to be between the spring plate and bushing and not the bushing and frame.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Thread Tools | |
Rate This Thread | |
