-   -   More heater ducting questions... (http://forums.pelicanparts.com/porsche-911-technical-forum/197640-more-heater-ducting-questions.html)
Rick Lee 12-20-2004 07:53 AM
When backdating the heat on my SC, I got the SCAT tubing from Aircraftspruce.com and am happy with it, though the 2.5" stock was still a tad too large. No problem. Now I'm wondering if I can use the same ducting and size stock for the heater flapper boxes. Are they the same diameter or smaller? Thanks.
Rick Lee 12-20-2004 10:46 AM
bump
KFC911 12-20-2004 11:23 AM
Rick, I'll defer to someone else for the answer (...but on my '88, I'm pretty sure it would work). Don't want to hijack your question, but what color was the SCAT hose? I just received some SCEET (from Aircraftspruce), and I was under the impression (from an earlier post), that it would be black...or some dark color. It turns out the SCEET hose I received is a burnt orange/rust shade, and I'm not sure I want to use that...yeah, I'm picky! Thanks...
ps: Does anyone know where to source black (high temp) hose? What I received from Pelican a while back isn't flexible enough...the SCEET would work great...I just don't care for the color.
Rick Lee 12-20-2004 11:33 AM
Call Aircraft Spruce and they'll tell you which is which. I did. I wanted the orange though. That's silicone. I forget what material the black ones are.
KFC911 12-20-2004 11:52 AM
Thanks Rick, I'll do that. VaSteve...clear out your PM in-box when you get a chance, and I'll reply again tonight.
