-   -   twin plug splitter (http://forums.pelicanparts.com/porsche-911-technical-forum/197722-twin-plug-splitter.html)
Jeff Alton 12-20-2004 02:27 PM
twin plug splitter
Anyone ever make their own twin plug splitter for use with a 964 distributor on a motronic car?? Can it be that hard?
Jeff
Jeff Alton 12-21-2004 05:52 PM
Anyone??
Carrera3.5L 12-21-2004 07:05 PM
C'mon Jeff, pony up the dough like the rest of us.:)
Ralph
P.S. - PM me what you found out with the P's & C's.
Jeff Alton 12-21-2004 10:10 PM
Fair enough.
tholyoak 12-22-2004 08:12 AM
Nah, save your money for other stuff :)
I owned one of the splitters from Andial. Pretty simple. All they did was use two ignitors just like the factory did on the 964. I can't see why you couldn't just by the twin coil and ignitor setup from a 964 car and use the single trigger wire from the 3.2 DME just like the factory did with the 964. Would save quite a bit of cash.
Just wire it like this
http://forums.pelicanparts.com/uploa...1103735457.jpg
The dashed wire is the shielded signal coming from the DME
Todd
Jeff Alton 12-22-2004 08:48 AM
Thanks Todd.
Jeff
ChrisBennet 12-22-2004 09:09 AM
A simple duplication of the 964 circuit won't work. The ignition units "invert" the signal from the DME so in order to use them you need to invert the signal coming from the 3.2 DME before passing it to the 964 ignitors.
See this thread: Twin plug DME splitter? for more info.
-Chris
tholyoak 12-22-2004 10:17 AM
Well notice I said "I can't see why", obviously Chris saw why :)
Heck I'm just a biochemist. I still think you could make a better mousetrap for less money with the 964 setup if you have some electronics skills
Todd
Jeff Alton 12-22-2004 03:11 PM
Hmmm, good thread Chris, I had not found that one. This is getting interesting.
Jeff
Jeff Alton 12-22-2004 03:12 PM
Ralph, by the way, when is "dyno day"??
Jeff
