-   -   Which side of cam oil line connecting screw (#48), goes into the engine case? (http://forums.pelicanparts.com/porsche-911-technical-forum/198218-side-cam-oil-line-connecting-screw-48-goes-into-engine-case.html)
H.G.P. 12-23-2004 04:28 PM
Engine case diagram (early 911 Pelican diagram), #48 screw connector, cam oil lines to case:
Which side of the screw connects into the case. The left part (in the pic below) which has the "lip"(that looks like a washer but is actually a part of the screw connector), or the right which doesn't have the "lip"?
http://forums.pelicanparts.com/uploa...1103848040.jpg
H.G.P. 12-23-2004 04:44 PM
That's as clear as the old (cheap) digital can give at close up. But the "lip" that looks like a washer, is still quite visible in the photo.
The "lip" (washer looking part), is just to the left of the "nut" looking part of the screw. The entire thing is one solid unit.
Early_S_Man 12-23-2004 05:30 PM
It only goes on one way ... the case threads are M12 x 1.00, and has a 'flat' surface that the sealing ring seats on ... the other end takes the compression nut and ferrule from the hose end.
randywebb 12-23-2004 05:38 PM
Just a hint for the next time - take the pic from further away and then expand it in your imaging software. Grainy is easier to see than blurry.
H.G.P. 12-23-2004 05:54 PM
OK, thanks Warren. I was looking at this from just the case standpoint, after bringing in one of the cam lines I see now clearly.
Thank you.
