Seperating engine from transmission
I know this has been covered before, but I searched and could not find the answer.
When seperating the motor from the tranny, besides disconnecting wires, the starter, and the four nuts, is there anything else I have to do besides use lots of force to seperate the two? |
Which engine? usually the throw out arm needs to be moved out of the way. but again, which engine are we talking about.
yeah, you have to release the clutch lever arm thingy on the trans before you can separate the two.
If you are having to use a lot of force, you've forgotten to do something, I think. At least I've never had to use much force to get the 2 apart. |
Sorry, 78 3.0 is the motor.
