Turn signal
I had a front (passenger side) turn signal bulb burn out yesterday on my 77 911S.
After removing the old bulb, I found that neither the new (1157) bulb nor the old one would fit back into the socket properly. Both seemed loose... even though I fiddled with the stupid things for over 10 minutes. For example, the new bulb lit up OK, but only when I held in in by hand. OK, so is there some little trick I'm missing here? Should I take the whole fixture apart just to change a simple bulb? -MAS |
rotate bulb 180o -- & not the prongs on the side of the base are offset axially
and... check the tabs in the socket - make sure they are not bent too low clean it all up carefully & smear a thin touch of dielectric grease on the mating metal portions be sure th rubber vent thingie is in the housing and is open and clear. |
RANDY,,,Isn't it ORGAN (m' just being a wise ass)
Or'gun
| All times are GMT -8. The time now is 07:19 AM. |
