Chain Housing Gaskets:curil T or permatex copper coat?
Or dry.
Dry didn't seal them up last time so I'm thinking about trying something a bit different. What will work better? Thanks. |
surface the ends of the housings on a sheet of sandpaper on a flat surface first. they're always warped a bit. dry is supposed to work, because the gaskets are coated with some sort of sealer, but sometimes there's minor seepage. i use K+W coppercoat spray. let it tack up before using.
Now in 993 land ...
If they are flat and torqued evenly and to the correct spec, they should not leak when installed dry. I keep sealants to a minimum, especially in an engine that is full of spray bars, piston squirters etc.!
George |
