Shift knob cap
After searching and reading bentley, I still don't know how to "gently pry off" the shift knob cap without destroying it. I just got a new stock shift knob and want to install it.
What should I pry the knob cap off with? Seems a small screwdriver would destroy the cap. On the 87s we need to remove the cap to access the allen screw.
Thanks. (and Merry Christmas!)
-Steve
'87 Carrera Targa
Old 12-25-2004, 10:15 AM
$80 for a shift knob - and you didn't spring for the extra $3 for a sparkling brand new cap?!?
Old 12-25-2004, 10:27 AM
racerdoc911's Avatar
I used a narrow X-ACTO blade. Got the cap off without damage. there is a "gasket" between th knob and the cap. that got kind of messed up, but still usable. You are definitely better off buying a new cap.
80 911SC Coupe, Grand Prix White- 3.2l twin plugged,Electromotive EFI w 46mm PMO throttle bodies, Fabspeed RSR headers/exhaust. 305whp.
Old 12-25-2004, 11:20 AM
Ya. I kinda blew it on that part. Might end up buying a new cap. I'll try racerdoc911's X-ACTO blade method first. Let's hope I don't spear my hand.
Thanks guys.
-Steve
'87 Carrera Targa
Old 12-25-2004, 11:27 AM
Wavey's Avatar
The cap has a pretty wide edge under it, too wide to go to the bottom on the first try. You have to work around it, a little at a time. You're more likely to damage the shift know than the cap by prying against it.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 12-26-2004, 10:31 AM
Yup, that' exactly what happened, the old knob is history now. But since I was installing a new shift knob anyway, no prob. The old cap is a little gouged now but I ordered a new cap yesterday. So as soon as fed ex gets here, I'll be all done.
Thanks to all.
BTW, Since I decided to toss the old cap, I ended up using a butter knife and then a small screwdriver to remove the cap. Not recommended if you intend to re-use the old cap or knob.
-Steve
'87 Carrera Targa
Old 12-26-2004, 12:34 PM
