1983 Euro SC Coupe : Correct Aerial?
I currently have a fender mounted screw out fixed "whip" style aerial that I'd like to replace with an original. Is the original the automatic telescoping version that rises/ falls when the radio is turned on, which would explain the tucked up wire coil in the inside fender, or the manual sort that you pull up/ push down after it's been unlocked at the fender with the small aerial key? I had one like this on my 77S. Or, are either one correct? Pros/ cons? Thanks!
billybek?
Old 01-05-2009, 01:11 PM
sudo apt-get purge 930
equality72521's Avatar
I believe the power antenna was mounted in the passenger fender while the manual was in the driver side. Which side is yours in?
--clutch-monkey
Old 01-05-2009, 01:21 PM
Sorry about that - it's on the passenger side.
Old 01-05-2009, 01:24 PM
My Euro 1979 930 is in the passenger side and is power.
--clutch-monkey
Old 01-05-2009, 01:34 PM
Thanks Mark. Good to know.
Old 01-05-2009, 01:35 PM
gulkster's Avatar
I have 1983 ROW as well. Mine is power, and on the passenger side.
Old 01-05-2009, 02:35 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
I have a euro 81 SC and mine is NOT power and on the drivers side.
Yours (slw911SC) was probably removed to save weight, or replace a faulty unit at some point.
1981 SC ROW Coupe
Old 01-05-2009, 02:40 PM
Originally Posted by SpeedracerIndy View Post
I have a euro 81 SC and mine is NOT power and on the drivers side. It was probably removed to save weight, or replace a faulty unit at some point.
AFAIK, if it is on the driver side it was always manual. I "could" be wrong though.
--clutch-monkey
Old 01-05-2009, 03:13 PM
crustychief's Avatar
79, drivers side. manual.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 01-05-2009, 03:27 PM
Go Speedracer, go!
Yep, that's what I was gettin' at. What I meant to say was that the original poster (slw911SC) probably originally had a power unit that was removed due to being faulty or in the never ending battle of weight savings.
I edited my original post to clarify. Sometimes it makes sense in your head and just comes out wrong in text.
1981 SC ROW Coupe
Old 01-05-2009, 03:56 PM
'78 Euro delivery car, power, passenger side.
And it works!
Scott
'78 SC mit Sportomatic - Sold
Old 01-05-2009, 04:56 PM
group911@aol.co's Avatar
The power units won't fit in the left side while the manual ones will. The fuel hoses and a/c drier are in the way on the left.
Thanks,
Bob
group911@aol.com
Old 01-05-2009, 06:40 PM
AUS911SC3's Avatar
78 Aus delivery (same as Euro) sporto, driver side auto - original
Old 01-06-2009, 03:34 AM
Correct. I think the unit was probably faulty, and replaced with a non power unit at some time. The wiring for the power unit is still intact, and the radio connection is - just disconnected. Although, the screw out "whip" style unit that is currently installed is very practical. Just sourced a power unit for $45.
Thanks everyone for the comments!
Old 01-06-2009, 09:43 AM
