How much does a dash weigh?
Mine came out in pieces, thanks to being siliconed down... I also cut out one of the defroster vents, which turned out to be a PITA - would be easier with the windshield out, so I'll wait until then to do the other side.
I'm going to try the felt trick.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I would think that the dash would weigh close to nothing... a pound or two... why did you cut it out...?
commandant of the compound |
drag racing the short bus
I have an '86 dash in my garage. I'll weigh it for you later today.
The Terror of Tiny Town |
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
The one out of my '76 without defroster vents weighed 5.5lbs on my freight scale.
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
Between 5 and 6 pounds seems about right.
Allen, the point of this project is to create the lightest track 911 I can, so 5lbs for almost free is significant. I estimate I'm back up to 2100 now that the cage is almost done.
Thom, I didn't weigh it, but the glass dash that Damon makes (Series900) is very light, can't be more than a pound or 2.
I went with this dash for 2 reasons: 1. I didn't like the sharp edge on the gauge cluster. I could see sheered off fingers in an accident. 2. Has the stock overhang for a little better shade from sun. It also looks good. The build: http://forums.pelicanparts.com/porsche-911-technical-forum/168286-installing-fiberglass-dash.html#post1509804
Tru6 Restoration & Design |
