73T right blinker not working
Help!
I am going crazy trying to figure this out. My right side blinker does not work. The bulbs are good and the fuse is good. When I switch the right blinker on, both blinker indicators flash inside, but nothing outside. I am not getting any power to the fuse, so I traced the wire back to the light switch. No power there, so I went to the blinker switch. When I switch the right blinker on, I have continuity between the grey and the grey/red wire. But I have no voltage at the grey wire. If I switch my left blinker on, I have voltage at the grey wire. I am confused. The way I am interpreting the wiring diagram, I should have voltage at the grey wire whenever the ignition switch is on, regardless which blinker is switched on. My first thought was a ground issue at the light housing. But if the driving lights work the ground should be ok, right? Plus when I tried to measure voltage, I used the same ground for the right and left side. The left side was fine, but not the right. Please help! Thanks! BK http://forums.pelicanparts.com/uploa...1104454704.jpg |
tabs bent that bulb nipples seat against?
search on turn signal + my name for some threads |
other thoughts - corroded fuse bayonet bases; bad gnds ----> that are not so bad that big amps won't flow but are bad for a small amp signal....
| All times are GMT -8. The time now is 09:38 AM. |
