-   -   Where is the type number on a 915 (http://forums.pelicanparts.com/porsche-911-technical-forum/199284-where-type-number-915-a.html)
Shuie 12-31-2004 03:51 PM
I can't find it. I found 3 casting numbers, but I dont see a 915/?? number. Where's it at?
TIA
5speed 12-31-2004 04:12 PM
The number is stamped on a large flat boss underneath the differential, near the drain plug.
Shuie 12-31-2004 04:42 PM
Is that where the serial number is also?
5speed 12-31-2004 04:55 PM
The number should be 915/tt xxxxxxx or if you are lucky 915/tt 12 xxxxxxx. The tt would be the type, the xxxxxxx would be the serial and the 12 would be for factory LSD.
Shuie 12-31-2004 05:45 PM
Negative on the LSD for sure, the shafts spin in opposite directions when you turn them by hand.
Thanks for the help!
