Oil cooler leak
For years my 82 SC has been amazingly oil tight, but recently it has started to drip a significant amount of oil. The oil appears to be coming from the primary oil cooler mounted on the engine. I'm going to pull the cooler and install new o-rings. There's not anything else in that area that would normaly cause a fairly good oil leak, is there?
Regards, Jerry Kroeger
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
you might want to ck and be sure it is not the thermostat o-ring before you pull the oil cooler off.... also ck the oil preesure switch back there.
