-   -   how to unglue rear view mirror (http://forums.pelicanparts.com/porsche-911-technical-forum/199598-how-unglue-rear-view-mirror.html)
rob_in_sotx 01-02-2005 08:45 PM
I improperly positioned the mount for the mirror on the w/s. Does anybody know how to unglue it so that it may be repositioned? Help Thanks
tab tanner 01-02-2005 08:54 PM
A rasor blade, VERY carefully work it around all the sides. TAKE YOUR TIME don't rush it or you will break a chunk out of your windshield
rob_in_sotx 01-02-2005 09:00 PM
Makes sense, thanks tab.
Robert
RoninLB 01-02-2005 11:28 PM
I've used a heat gun on both the outside and inside patch area to soften the glue. I did it gently to avoid cracking the shield.
Victor 01-03-2005 04:28 AM
You guys have no idea.
Put on a crash helmet and give it a light tap with your head. Guaranteed to pop off - no fuss - no mess.
Worked for me about 3 times so far.......
TMH 01-03-2005 07:00 AM
I just did this on the track car as the rear view mirror on the windshield is useless with the roll bar in place.
Some have more patience than I, but I could get nowhere using a single edge razor blade. I ended up using a razor saw, and attacking the "button" on the windshield from various sides alternatively.
I think it took me about 15 minutes before the glued spot was so small that the button just popped off. Then I cleaned off the adhesive residue with a single edge razor blade. Can't tell the button was ever there.
Here is a link to the razor saws I am talking about:
http://www.stockade-supply.com/cat-tools/razorsaw.html
Good luck,
Tom
