IAN IAN is offline
JB Weld to fix Scratch in Cam Housing, see Photo
I'm in the process of replacing the cam seal on the very front left side cam that drives the MFI pump. Somebody (before me) put a small gouge in the cam housing. Most likely from removing a seal. I think this gouge could prevent the seal from sealing properly.
I'm thinking about trying to get a little JB Weld in there to fill the scratch.
Any tips on doing this? I have not used JB Weld before. What should I clean the area with first? Will brake cleaner work okay? i was going to apply with a popsicle stick or something. Do I need to coat this with anything after I JB Weld?
Thanks.
Old 01-03-2005, 12:55 PM
Slumlord
Porsche_monkey's Avatar
Brake cleaner, fill it, let it dry. Sand it gently without removing metal nearby. Should work.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 01-03-2005, 01:06 PM
Super Moderator
cstreit's Avatar
Heat helps JBWeld cure BTW. However it doesn't go on like "putty" so expect it to run. Use very small amounts and build it up/sand it down, otherwise you'll be sanding out a lot of stuff. should be okay. If you are splitting the cases, have someone weld then machine it.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-03-2005, 01:11 PM
use a pocket knife to carve off the raised burr, and also to apply the JB.
just squeegie it into the groove and don't leave any beyond it. to hard to get to to sand it off with the cam in there.
206 637 4071
Old 01-03-2005, 01:25 PM
Slumlord
Yea, those guys are both right. Maybe rotate the engine and apply it with the groove closest to the floor, then squeegee it flush and let it harden.
84 Cab - sold!
Old 01-03-2005, 01:30 PM
Shaun @ Tru6's Avatar
a coffee stirrer from Starbuck's would work well in applying and squeegeeing the JBWeld.
Tru6 Restoration & Design
Old 01-03-2005, 05:55 PM
Slippery Slope Victim
NY65912's Avatar
JB weld for sure, hardens like metal. I've repaired a few VW engine cases in the past. Just make sure there is no oil on the surface.
MikeČ
1985 M491
Old 01-03-2005, 06:02 PM
And use a non hardening sealer around the edge like Curil T when installing the seal for added protection.\
-Andy
Old 01-03-2005, 07:21 PM
911SCfanatic's Avatar
I assume this approach would also work on wheel hubs in the seal area? I've got a hub with a few scratches. Sounds like the JBWeld + Curil T approach would be perfect.
Bill G.
'68 911 Ossi Blue coupe
Old 01-04-2005, 06:51 AM
Slumlord
You mean a rim leak?
Old 01-04-2005, 06:53 AM
No, the hub. I'm talking about the seal adjacent to the inner wheel bearing.
Bill G.
Old 01-04-2005, 07:48 AM
