Who is John Galt?
Rondinone's Avatar
WUR gurus
79SC. Cold control pressure = 0.5 bar. That's way too low. After 15 minutes with key in on position, it climbs to 2.0 bar. Still too low. System pressure = 5 bar. Residual pressure = 2.0 bar 30 minutes post shutdown. Vacuum on WUR port does nothing.
Is low control pressure a normal failure mode for the WUR? Thanks,
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 01-07-2005, 07:27 PM
Somewhere in the Midwest
MotoSook's Avatar
You'll have to make the WUR adjustable...to bring the cold and hot pressures up.
Old 01-07-2005, 07:34 PM
Elombard's Avatar
Check volatage to it. Pull the plug and start the car and check the voltage at the plug. I think I had similar press. when I lost voltage. The vacuume had no effect. How does it run. What happened when it changed? Have you seen the web site from the guy from rennlist. He is a guru I was able to e-mail him for some answers.
http://members.rennlist.com/jimwms/
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-07-2005, 08:23 PM
