Question fuel pump
hi all, Can someone tell me why my fuel pump is in the rear next to the swaybar mount?(75 targa)
The car had an 83 engine installed,before I purchased it,I'm assuming that has to be part/all of the reason?
Would it make sense to move it to the front location?
thanks.......
Old 01-06-2005, 06:15 PM
randywebb's Avatar
are you getting vapor lock?
if not, just leave it alone.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-06-2005, 10:16 PM
IROC's Avatar
Your fuel pump is there because that's where the factory put it. They didn't move them forward until a few years later.
My '76 has a 3.2 in it and I mounted the Motronic fuel pump in the same place (left rear like yours) that the CIS pump resided. No problems. Kinda like Randy said, "don't fix it if it ain't broke".
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 01-07-2005, 04:19 AM
fuel pump
thanks guys, just wanted to know for sure,cause it didn't look like someone moved it,looks like it was there from the factory,
appreciate the response.
Old 01-08-2005, 08:24 AM
The fuel pump in my 76 is in the front, attached to the suspension crossmember.
Old 01-08-2005, 10:21 AM
