Electrical / Headligths help
The high beams on my new (to me) '84 930 with a 993 body kit and Litronic (?) headlights are not working. Low beams are working fine.
I installed the Sucro relay kit and high beams still not working, checked the stalk and all the connections seems to be in good condition. At the top of the fuse panel I switched the high / low beam cables (white and yellow) and still only the low beams work. What to you think? I'm guessing that something is wrong at the headligth end (bad connection). As I side note, the headlight switch is not dimming the interior lights, can this also be a problem? Any ideas?? Thanks and Regards PS. I do not have the electrical schematics for the '84
Jordi Riera '84 930 (modified) |
one of gods prototypes
i would start with a multi meter or test light and confirm everything is working at the relays you just installed.
were they working before you added the relays?
Brought to you by Carl's Jr. |
Bell, thanks for the reply. Long beams where not working before I installed the relay kit (I was not expecting for the relay kit to solve anything)..
What really confuses me is why when I switch the cables for the low/high beams at the fuse panel only the low beams still working (in the same position of the stalk). Time to find the test light and the multimeter..
I would rather be driving
Check for continuity between the fuse box and the lights themselves. Do you get 12V at the fuse box when the high beams are switched on? This will isolate the lamp or the switch side. Then start back tracing through each connector until you find the break in connection.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thanks Jamie will do that.
If I remember correctly the headlight switch 'energizes' the system and the stalk just acts as a switch between low and high beams, correct?? Does the headlight switch has separate circuits (contacts) for low/high beams?
Jordi Riera '84 930 (modified) Last edited by jriera; 01-06-2005 at 07:14 AM.. |
Heck, I’m only 5 not 71!
This is a link to the schematics for the 1982 headlights. Granted it is not the exact year but it should be the same type of circuit layout. fuse 7&8 are the high beam and 5&6 are the low beam.
1982 schematic If you have the relay added for the headlamps it should look something like this
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
