H.G.P.'s Avatar
NGK BP7ES will they work in a 69E Coupe?
Will NGK BP7ES spark plugs:
1. Fit in 2.0 heads 69E coupe? and
2. Are they appropriate for the car/year?
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 01-06-2005, 12:05 PM
I guess you have 14mm threads, so they should fit.
I'm running BP8ES on mostly hy and they stay very clean. The 7 is a bit hotter. If you bought them then install them. I like to run the coldest plug I can get away with.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-06-2005, 12:34 PM
Porsche Doc's Avatar
Thumbs up
Yes, They will work OK.
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 01-06-2005, 12:35 PM
Licensed User
Shuie's Avatar
They should work. You may want to go to the BP8ES when the warmer weather comes around. The BP6ES plugs are definitely too hot.
Old 01-06-2005, 09:33 PM
