-   -   Help with 2.2 MFI Motor (http://forums.pelicanparts.com/porsche-911-technical-forum/200239-help-2-2-mfi-motor.html)
Jim Smolka 01-06-2005 11:47 AM
Through some horse trading, I have a complete 1972 2.2 motor with MFI system. The motor has been sitting for a number of years (5+) and the condition is unknown. The motor will turn over by hand.
What would be the best way to determine the condition and to clean out the MFI system? I could build a stand to "bench test" the motor. Anything to do to the MFI system to clean it?
Grady Clay 01-06-2005 02:26 PM
Jim,
First off, if original it can’t be a ’72 2.2. It can be a ’70-’71 2.2 or a ’72 2.4. What is the S/N and Type number stamped on the case? Do you know any history?
Most important, don’t assume anything. Dismantle it completely and build from scratch. Without that, you will probably destroy a perfectly rebuildable 911 engine and loose what you paid.
Start with a plan. Gather information first. Search the Forums for info, then disassemble and measure everything. With full knowledge, devise a new plan.
What do you want to use the engine for?
Best,
Grady
